beyondloadedSE
i say screw it i'm gonna try it i have searched this forum over and over and haven't found anyone that has really done the research if some has pm me let me know what i am getting into
Nobody's done it. I've kinda already mentioned what needs to be done and its no where easy or inexpensive. If I had to guess, its probably in the ballpark of $20-25K or more. It's hard to guess without diving into it.
This isn't just a swap where you throw in a 3.5L and your good to go. Nothing is the same, which means, you'll have to figure out how to mount the engine in the car, assuming it even fits perfect, which it won't. Some modication to the firewall, mounting locations, etc will need to be changed. Engine mananagement? Spending $2K on a standalone or buying an entire parts car to get the wiring harnesses? Transmisssion? MTX-75 wont work as it sits right now so you'll need an adapter plate, $$$$. Im sure the axles and intermediate shaft will all have to be completely redone. Don't even want to think how much that intermediate shaft is going to cost. Cooling system? Is the 2.5L cooling system going to cut it? Doubt it. Will it fit? Doubt it. Time for something custom or do some serious fabrication to the car to make the 3.5L radiator, etc work. I'm sure these are only some of things that need to be done to make it work.
Still going to do it?
