ghosstryda
I've been trying to remove the bracket assembly of the front passenger seat and I'm having a major problem with the rivets.  i used a small drill bit and tried to drilled the center of the rivet but all that did was wear down my drill bit.... so i then bought a grinding tip for my dremel and tried to dremel the head of the rivet off.  that didn't work as well as i had hoped.  the head of the rivet was grounded off but the rivet is still intact and firmly attached to the seat....  its as if it was welded onto the bracket assembly... this first rivet has taken me more than 3 hours and is really pissing me off
any suggestions or recommendations on how to remove the f'ing thing would be very much appreciated... thanks in advance
