the height of the shifter is irrelevant, only the distance from the pivot point to the lower shift cable mounting point. you could have a shifter thats 2ft tall and if the distance between the pivot ball and the lower cable mount is large enough, still have a throw that is shorter than stock. the B&M doesnt change that distance, just the height of the shift knob, and while that does shorten the throw slightly, its not much. the Steeda shifter moves the lower mount 10mm farther from the ball, so even though it is slightly taller than the B&M, the throws should be shorter. The CFM shifter moves the lower mount 15mm from the ball so its throw is even shorter than the Steeda. it also has an adjustable height above the ball with its lowest setting (about 10" overall length) being right about the same height as the B&M and its highest setting about an inch shorter than stock. it also comes with a riser plate so you dont have find one or fabricate one.
