ST220 UIM on SVT LIM. Possible?
SQuAlL-NT
anaheim, CA, USA
I bought a ST220 UIM a while ago and still didn't figure it out how to install yet.
My engine is sable 3l hybrid, split ports head, SVT LIM (split ports) and SVT UIM for now.
I found posts about similar thing but it didn't solve the problem.
http://www.contour.org/ceg-vb/showthread.php?74022-Oval-port-UIM-on-split-port-heads
I am not gonna make the head oval port, but i can change the LIM.
However, i am still using return style fuel rail and not looking to change it if not too necessary
Injector properly staying at the side (instead of at the middle like most oval ports).
I talked to NPG for a custom adapter basically revise the one they have
However, i dunno how much space i have for the adapter.
Also, What should i do with the EGR? It is in the way and i can't put on the UIM to measure the height.
I could use the NPG adapter under the oval port LIM, but i will need to move the fuel rail right?
IS there any Oval port LIM that have the injector at the side?
Does anyone ever success putting a ST220 UIM on SVT LIM?
Thank you guys
No you cannot use a st220 uim on a split port engine.
The NPG adapter does the opposite of what you want to accomplish.
