Datonaku
The temperature gauge reads just under the "N" sometimes the "O". Would this cause the fans to not cut on? The motor acts fine when cruising at highway speeds does seem to get alil hot in stop in go. Checked fuses already.
I believe that the high speed should turn on when the A/C is turned on. As I recall if people where having issues with the fans coming on at the low speed or not at all they would always turn on with the A/C.
