MemphisZ28
- Joined
- Feb 28, 2011
- Messages
- 18
Ok Im desperately trying to fix this so I can ditch this POS. I Get no power under acceleration, but if I take off smoothly like a hypmiler, it barely if at all does it. Seems like it has no upper rpm/mid rpm power. Since its such a peice of crap it has no tach, and I cant hold my scangauge and drive, so I cant tell you exactly where. Id guess 2.5 or 3k and up. It pulls, then hesitates , then pulls a little, then hesitates, if you floor it it doesnt accelerate. NO check engine light. I hooked a fuel pressure gauge up and it read 0psi.... SO im thinking FUEL PUMP. Replaced fuel pump, does the exact same damn thing. Filter too. I was thinking clogged cat?? But wouldnt that set of CEL code? Did on my camaro.. How do I test for that? What else should I check? Had new timing belt, tensioner, plugs, and coil about 8,000 miles ago. Has Mastercraft wires as well. The only thing I dont have a receipt for from prev owner is 02 sensor.. I do have a scantool. Can someone point me in the right direction who knows their stuff? I keep thinking it feels like a clogged cat but why would it jerk and hesitate like that? Does not feel like a transmission problem, it (feels like)misses at idle in gear only, in park it doesnt, which further confuses me...
