Teal4Banger
On a side note, if you are running higher-than-stock RPMs, and have replaced your springs, etc, then a cam will really help your top end. Also, if you are running higher RPMs it may be beneficial to swap heads (easier than trying to convert your head to mechanical lifters I believe) and go with mechanical lifters as I'm told they perform better at higher (over 7000???) RPMs. I'll see if I can dig that article up as well and post a link.
I'm not convinced that your problem is from your cams however. I can't recall a time where someone was maxed because of their cams when dealing with the HP range you are.
Good luck.
Good luck.
