Rick in NC
Be Gentle I'm New Here
'96 Contour GL, 2.0L
The wire insulation everywhere under my hood is brittle and falling apart. I've since found out this is a common problem with Contours.
So far only the fuel injector wires are causing a problem. I spent a couple of hours coating them with liquid-tape to get me by. I want to splice in some new connectors so I can hopefully get past the worst part of the flaked wires.
I'm really a novice at car repair so when there are multiple choices for the part I don't know what's what.
Rock Auto shows two different choices under "Fuel Injection Harness Connector"...
Part # S697 for $4.66 each or
Part # SK25 for $9.46 each.
And there are few other choices under "Fuel Injector Connector"
What I want is the cheapest option that definitely has the wire leads attached.
Can someone tell me exactly which part number I need?
Thanks,
Rick
Thanks,
Rick
