Does anyone know if the new Duratec 35 engine will fit in the Contours? Sounds promising, might do that instead of the AER engine upgrade in the future.
That would be so much cleaner.
maybe its the same as a 3.0 but stroked? if so would that simply a swap.
The 3.5L is suppose to be slightly longer which means it probably won't fit. We don't have much room as it is between the pulleys and the fender well.
just because it's longer doesn't technically mean the transmission has to move since you're doing custom motor mounts most likely anyway.
Just depends on how much longer it is.
It is longer, taller, and the crank centerline is different.
And if one were to go to all that trouble and expense, why limit yourself to a 3.5L ??
And why limit yourself to fwd?onder:
/Well, I don't know about you, but my engine has about 3/8" in front of the damper.
/Well, I don't know about you, but my engine has about 3/8" in front of the damper. If it is moved any more over than that, i t will require me to cut up the inside of my Wheel Well for extra room. So assuming the dif. between the 2 engine is more than 1/2", the tranny would be shifted which would require new axles.
I don't know all the differences. I'm just saying is a lot more complex swap than the one we already have available which is basically remove, disassemble, reassemble replace. his one would require a lot of fabication. Thats 1 of the reasons why this swap will never replace the current 3L swap.
At a certain point the contour starts to have diminishing returns to scale.. IE. that the more money you dump into it, the less power you get. Your still going to end up with an old car that drives the wrong wheels. Just my .02
