FavoriteMystaque
- Joined
- Oct 16, 2004
- Messages
- 1,192
The 20 Amp fuse F4 leads to the 4 pin coil connector VT/BK wire (purple) and pin. Wire 14-DA3 is it, see below. The 12 V power is switched on to Fuse F4 with ignition key through a relay, which turns on the PCM power as well, which reminds me, is the PATS red LED light blinking (on center dash or in the clock)?
