TRicker
LIM sizes:
SVT vs post 98 V6 cars. bore size same or different? thanks for any info.
the non svt lim on the contours are all the same size. early svt are 31/32mm's later svts and all returnless cougars are 33/34mm's. essentially just 3l split port lim's with a different shaped secondary actuator rod
sho shop made some big bore lims as well,although it dont recall the sizes...
37mm was one of its sizes thats for sure.
If you are looking for a LIM. Pick up a cougar LIM from a 2000+. It is indentical to the final design LIM the svt contour had.
Would that be an easy option for someone with a 98? if 2000's are returnless, wouldn't it be mostly useless since they need return style?
Swap the fuel rail and injectors. Takes a few mins.
its been done. the fuel rail will work fine. its the vac. actuated secondaries that'll need to be custom fitedI have a '95. Can I use my existing return-style fuel rail with late-model SVT/Cougar LIM?
i've had to do that before...let me know if you get the shafts out..i couldnt figure it out,so i had to cut them into lots of little pieces.the vaccum actuated secondaries are WAY smaller than the split port 3L ones. i picked up the split port 3L LIM to use as a test in gutting the secondaries. too bad all the screws stripped so i have to drill them out or cut the shaft out, lol. i'll get pics up when i get em gutted, holes filled, and ported up.
