Do you think the TQ is so high due to the stock manifolds?
Look, after analyzing the dyno data we have found that the torque data conversion was wrong in the software.
The guy running the dyno did not get good RPM data which is needed to convert the torque numbers from the HP numbers.
The dyno measures the HP and speed of the car, or RPM of the engine. It needs to back-calculate the Torque from the HP numbers.
Take a look at the graph and you will see that the torque and horsepower curves do not cross at 5250. This is only due to the conversion issue I described above.
I plotted the horsepower numbers into excel and I made a correct conversion for torque.
Peak torque on the 237wHP run was about 259 wTQ
I'm down here in Louisiana and visiting Joey and helping a bit with details on the car. We caught the error from the dyno and we wanted to be honest and straightforward about the corrections.
When I get back home I'll be able to do a screenshot of the excel graph and you will see the corrected hp/tq lines.
Thanks for the understanding.
Also more news:
We ran the car at the drag strip just to get an idea of what it might run. We ran into some Air Fuel issues and had to shut it down in 3rd gear because EGTs got high and the warning light came on.
This happened because we installed the 24#/hr injectors and we don't have it fine tuned yet. My tuning software is at home on my PC so I made a guesstimate tune and brought it withme to load into the car. When I get back home I'll adjust the tune and then we'll see what it runs.
For now, at 3.5psi the car ran 14.6@91mph in the 1/4, with a 2.2 60' and cutting out of the throttle at the top of 3rd gear. So I basically coasted over the line in 4th gear. We do have a timeslip to verify our times.
I'm guessing this car will be able to run about a 14.4 at 94-95 at just 3.5psi, and about a
13.9-14.1@100 with just 6psi.
We are extremely happy with the nice smooth torque curve for this car and the usable performance.
