FastFord
Where does one get that there oil cap?
So does it run and everything now??
...Now my question is how did everyone else run their intake pipe for the turbo through the fender. I didn't have to cut away any more of the opening, but I feel like it's going to be awful close to the fender and bumper if I leave it as is.
i would definitely move that maf closer to the tb. that large bend before the maf will skew maf values alot, which causes alot of problems tuning
Going by your pic, u're gonna need a smaller angle for it to fit. Simply disconnect the intake tube at the coupling where it meets the MAF and roll the pipe upwards. The filter will eventually sit inside the bumper, so you'll need to move the pipe upwards. Makes sense?
It does. However the tube isn't tightened in the coupler. As it is rotating the tub up it contacts the header panel, specifically, right where the fender bolts to it. You can see it in the pic.
I don't suppose anyone has pics of their installation of this tube?
Oh I see why it's having a hard time fitting... The tube is too far up front in the hole created in the fender. Mine isn't nearly as nice looking as yours, but the hole is further back towards the fender well, allowing the angle to be just right. All you might have to do is to reduce the length of your pipe instead. Oh and mine hits the header panel as well. Once you attach the intake filter, it should sit right below the header panel & inside the bumper. And as for those using Timken, it's probably a name recognition thing.
moog brand is the only thing id ever recommend now
The hole looks nice partially because I didn't cut itThat is the factory opening for the duct that feeds the SVT filter box...
Ah i see... I've had my car modified for so long that many times i forget what's on a stock svt. Nevertheless, that's the problem. You need to widen that hole.
I seemed to remember people cutting that opening. However I figured the piping wasn't laying out well for them and they were forced to cut it. I had hoped that Joey had designed his piping such that no cutting was required for that tube.
That said I wonder if I could still make it work without cutting it. perhaps cutting the tube and putting a bend in there. Although I'm not sure where the filter was supposed to end up, which was why I was hoping for a picture somewhere.
I found the bushings on my control arms were shot and the ball joint boots had cracked leaking grease. So no I'm contemplating building my own tubular 4 bolt LCA's or just buying some cheap eBay control arms to get me going in the mean time
pleeeeeeez make some ' to die for ' 4 bolt arms .....G. :laugh:
