KAOS_3.0
every time this thread shows up in my subscriptions, I click on it hoping for pictures....
I wonder if the car will sound like it has a jet engine in it with that pump. The Walbro 255 pump is crazy loud in my car.
Looks good, I should have had him do mine while I had my dash out...Not much of an update, but thanks to CrazyTalkSVT, I got my dash cross brace blasted clean of all the rust that was on it. I painted it over the last couple of days...
Sad this is this is the only thing that has been painted. Shooting for next weekend now. As this weekend is shot.
Any engine can run E85 if tuned correctly. It's normally an issue for the fuel delivery system (lines, pump, tank) since E85 can eat away plastic and rubber. I think Mike is updating everything anyway so he could probably run whatever he wants.
I thought I read a while ago that it can also eat away at piston rings etc. So I was just wondering about that.
E85 seems to get lumped together with methanol, leading to all this talk about damaging stuff. E85 is far less destructive from what I can tell. It just tends to dry out certain plastics/rubber, and doesn't like paper gaskets IIRC.
On a side note: I really want to see this build support E85 as my E85 venture has lost it's funding :blackeye:
high resistance to detonation, I think its equivalent to 105 on the octaine rating.
The tank will be staying the same, but the lines may or may not be changing, and of course I am changing out the pump. Since I'm increasing the flow of the pump and then going from 199cc to 1000cc injectors.. I think I may need a larger line. Everything I've found says I should be running a -8 (1/2") supply and a -6 (3/8") return. Not sure what the return system have stock, but I may be able to get by with a -6 supply and a -4 (1/4") return too as a few people have been running that without problems. We'll see.
Well it's destructive enough for Aeromotive to say that it will require more frequent filter changes and possibly shorten the service life of their pumps...
mike, let me know when you are going to build a fuel system. my uncle splurged and bought all the billet -an wrenches and the "kool tools" fitting installation tools, and the proper line cutter. it will make the -an lines a breeze to build. i'll come down for a day with all his stuff and we'll get them built![]()
i just finished reading 950+ posts about your build (it only took me a week) and it seems that it has evolved from an engine build to almost a full on restomod. the time and detail that you have put into your car is simply amazing. i can't wait to see it finished. i do have a couple of questions though.
1. are you going to use subframe connectors? i don't recall seeing anything about them.
2. you traction bar, are you going to build once from scratch or are you going to modify one from another car? i know that you had touched on the subject but i don't recall reading anything specific after full race seemed to flake out on you.
