You're probably going to have problems with that drain. Almost certainly. If thats what it is
You realize this is not for the drain right...
It's for the Accusump when crap hits the fan and there is no oil pressure.
Nope, and I do remember you're running an accusump now but its been so long I forgot. Hose seemd too small which is why I said something. I see that one all the time figured I would check.
Well the hose is definitely not too smallI'm running -10AN for both the turbo return line and the Accusump inlet/outlet line, which is what is recommended for both. Thanks for checking though! I always like to double/triple check things as I'd hate to mess something up with this much time and effort invested.
I don't miss coating calipers one bit. Matter of fact, you will have a b-t-ch of a time trying to get parking brake assembly back together without marking up the coating. I stopped taking apart the ebrake before blasting. I would leave the rubber boot on to keep grit out of the mechanism, slide off the boot, mask off the butt end of the caliper for coating, then re-grease the mech and install the boot/zip ties like normal. The caliper doesn't heat up hot enough or long enough to damage the seal inside the back of the caliper.
Those t55's on the calipers are a PITA, I stripped three of them between two cars when I was building the coug from the wrecked contour.
Wound up sourcing grade 10 bolts with a 13mm hex head from NAPA. Problem solved!
This is why your an awesome guy Mike, because you're not a dick when people question you and/or try to give suggestions...
update!
I'm not going to be powder coating the end of the caliper that is going to be covered by the boot. There really isn't a point since it won't be visible.
2 years isn't long enough?![]()
...You can leave the ebrake mech alone, leave the ebrake boot on during blasting, pull the boot and mask during coating, and the mech and seals will be fine. Just re-grease the mech when finished.
Perfection takes time. I just needed to give you crap.
