elraido
I kant speel
Ok...looks like I am the old man of the MN Chapter at 30. :laugh:
Im only a few months younger than you....
ok...looks like i am the old man of the mn chapter at 30. :laugh:
Not quite, I'm 33.![]()
Yea but your no longer in the MN chapter :laugh:... silly Wiscony boy :crazy:
Say hello to variable mapped boost, the HKS EVC 6. Found a deal on eBay and couldn't pass it up. Saved myself $200 off retail. Cheapest I found it before that was $608 :shocked:
Never even heard of one of these. This build is going to be a really nice setup.
What are you planning on for the intercooler and radiator setup to prevent over heating problems like fastcougar had?
nice!!! it might be presumptous of me, but i'll venture and say that we're witnessing history. at this rate, u just might end up to be the person with the most expensive contour.
I myself with my setup have my fans kicking on at a lower speed to prevent high coolant temps to begin with (which he may have done as well I dont know), however that may not be enough if this car seems long durations of heavy loads (ie track events). I have in my back pocket a plan however. I have a spare SVT radiator that I can always send to Griffin or Fluidyne to make me a thicker core aluminum radiator. Also I can always step up to aftermarket electric fans which have a higher rpm to provide enough flow through both the radiator core and intercooler core... or the backup plan to that would be to run an air-to-water intercooler (I already have a high flow water pump and tank setup I can use) or... ok here is the list :laugh:
Plan A set fans to kick on sooner with SCT PRP (already done with my current NA tune)
Plan B mount intercooler/radiator core spray system electronically controlled to kick on in heavy load conditions
Plan C send in spare radiator to Griffin/Fluidyne to design core for heavy load conditions
Plan D switch to air-water intercooler to open up radiator core to more airflow.
Plan E switch to higher speed aftermarket fans
Plan F install water injection system
If none of these work... drive car off cliff
Hahaha it sounds like you have a plan, just wanted to make sure.
But hey if you do drive it off a cliff, at least let me drive it first.
setting the cooling fans to turn on sooner is a good starting point. I have done this with my car and the coolant temps stay in check. oil temp is good most of the time, except after a long run flat out it gets up there some but isn't bad.
Trevor's overheating problem was caused by a loose ground for the fan setup, which wasn't found till he pulled the engine and started selling stuff off.
This looks like a well thought out build!
anyone ever measure the volume of the 04 taurus mani?
i can do it i just dont know how you guys are doing it i want to do it the same way so it's accurate.
Yes I use a 250mL measuring cup and count the pours.
