hylix
o. M. G.
I KNOW!!!! I have that exact same powerbuilt creeper with adjustable headrest!!!! Only I replaced the casters with some super sweet ones...
The car's coming along nicely too.
o. M. G.
Looks like you can almost walk around in that garage now. :laugh:
o. M. G.
hey csvt 49, i know you already have the sct software to tune your car, but i would HIGHLY HIGHLY recommend the quarterhorse chip by moats.
why you may ask? because it has live tuning. being able to change a parameter while the car is running and see how it actually changes driveability. i would say this is a MUST for turboed cars.
it helps tune low end cells and increases throttle response because of it, but be aware you do have to use a dyno with Eddy Current Brake, (so any mustang dyno should work).
It does.IIRC, You can also a Tweecer RT in place of the QH chip, with the same functionality. Not positive about this...
If I do anything I would switch to running a MS2 system.
You could weld a tube in the hole, leaving some lenght of tube on either side of the frame rail and use silicone couplers to join the pipes on either side.
