yes I do believe the fuse for the O2 sensor heater circuit is in the engine fuse box. if that fuse is blown then you would get codes for all four O2 sensor heaters.
Since you have a 2k SVT you might want to install an updated pump. what pump did you install? The one from the SVT Focus? If you used one from a pre99 I am not sure the PCM could control it correctly.
