DanMyers
Hey guys, got a new head unti and an amp recently and I wanted to know where you mounted your amp? the amp I have is a Pioneer GM-D9500F, which is a very compact 800w 4 channel, and what I want is someplace that is out of the way, but still accessible without much work.
If you look up the amp, the dimensions are fairly small, so I can really put it anywhere, and was in fact thinking about putting it under the back seat on the drivers side since no one ever sits there, and the 6-disc that came with the car died and the control box is under there right now, so that's getting pulled out. However, heat is an obvious issue considering there is almost no airflow down there.
Additionally, I have read several reviews that this amp runs very cool, and those people have mounted them in places with little to no airflow, but still it may be a concern (I am brand new to amps).
So where did you mount your amp and what would your recommendation would be as to the easiest/best mounting location would be. Thanks in advance guys.
