Im from pennsylvania, when we go to florida we go to mannys chophouse. By far the best food. Their salad is amazing and their food is so good. Its always busy there but its definately worth the wait
When my BAT cat clogged like that it actually blew the 2 rubber DPFE tubes right off. Check that those 2 are still on. You need to reset the PCM...and see what codes are still active now that you've removed that big clog which was clearly causing some of your codes prior...
you could still leave the dpfe plugged in and it wont show that code...
check cylinder 5. plug wire and make sure its in there tight. Also pull hte spark plug out and check it for foulness.
