Ok well I did look at the how to but I still have questions:
-I have a yellow top optima will that work, I'm pretty sure its sealed?
-So the negative cable running to the battery goes into this module which is grounded to the body, then you run a cable from that module to the battery in the trunk. Same for the positive. Is that the jist of it? Or does something else happen to the ground?
-My car, as some know, has been brought back from a 2f2 nightmare. Instead of one cable running to the each of the connections (+,-) on the battery, there are 4 or 5 running to each one one. (so in other word if you look at the battery there is 5 reds thin cables running to the positive, and 3 black cables running to the negative.) So would I have to fix this or what the hell is going on with that?
Like I said the car was TOTALLY messed up, so I'm pretty much taking everything out that this guy screwed up and trying to fix it.
BTW how is it that just because someone doesnt know much about electrical side of the car, they are totally clueless about turbo's? That makes absolutely no sense. But whatever.....
