My wife's Contour ('96 2.0L ATX) started acting up last week. As we were driving it felt like the engine shut off but restarted on its own seconds later while the car was still moving, all electric accessories continued to work while this happened. It then died at a stop sign. I managed to get it to start and to get it home.
Once home it would start and either idle extremely rough or die immediately. I checked the MAF because I just replaced it and found a short in the wiring. I fixed the wiring and now it dies immediately after starting. I can get it to continue to run if I press the throttle although it is extremely rough (almost sputtering) and dies as soon as I take my foot off the gas. If I unplug the MAF it will run (rough, but it will run).
No CEL during all of this.
I seem to recall reading somewhere (maybe here) that the Contour will just revert to some sort of stock table or a limp mode if it doesn't see a signal from the MAF. If that is the case then I have to assume that some other sensor or wiring is defective (MAF tested fine) and that by unplugging the MAF the car is ignoring whatever is defective. Am I correct in this? If so what does this sound most like (camshaft position sensor, crankshaft position sensor, etc.)?
