96RedSE5Sp
You don't think safety is an important consideration when deciding whether or not to upgrade?
As much of a svt fan i am....
You might want to pay attention to these Very known common problems that occur with these cars, regardless of 50k or 150k miles on it...
1. 6cly rod bearing goes. so means new engine or overhaul is needed. So always put 1 qaurt extra due to oil starvation, because of our heads no draining oil fast enough.
2. Water pump failure
3. Dash warp...it gets ugly:blackeye:
4. Wiring harness rusts (sucks)
5. Diff gets eaten alive and breaks (it's like glass):help:
6. 1998 Rear springs got recalled because they rust out and break.
7. Headlights fade in alomost 3-5 years.
there is more but this pretty much covers the cars engine suspension trans etc etc...i lve them but i'm not naive at the same time.
This is pretty misleading. The diff isn't like glass unless you drop the clutch every chance you get, my 8 year old headlights have barely any haziness (and many new cars have plastic headlight leneses that haze eventually), not all cars prone to dash warp actually have it occur (mine didn't), the impellar on the waterpump was only a problem from '95 - '98.5 as they used a different plastic from '99 on, and IIRC the wiring harness was only an issue in '95. Feel free to correct me if I'm inaccurate.
It depends what you prefer really. I got my SVT at 152K for a steal of a price and have reached 163K with no major problems other than routine maintenence (brakes/WP/hoses) and a few other things that I will get too when my income stabilizes. It isn't as easy to work on a SVT compared to a Honda and parts may not be as easy to find, new atleast.
My 2 cents would be to check out the SVT in and out, get a price and take it from there, it never hurts to window shop. I also believe you may not want the Honda after you drive the SVT for a little while, but I wouldn't drive the SVT full time either. Hondas are not rare, SVTs are. This also adds a bit to the SVT experience IMO. If you would go with the 2 car route you could use the Honda until it craps out for work and use the SVT for play. The SVT is a fun car!
If you like the car that much, why not hunt down everything needed to convert to fuel injection? If the FI was only available on a different engine, why not go with an engine swap?
If you like your Honda THIS much, you may not be happy with ANY other car until the point where you HAVE to get one. That's what happened with my GSR.![]()
