Daytime Running Lights
doubt it as my local ford dealer couldn't find it in the system .... you need to order it from Teamfordparts.com
part number is listed previously in this thread
I will be ordering either from teamfordparts.com or fordparts.com. Took the part# previously listed to AZ nothing in there system as you suspected. Thanks for the input!!
yeah love the way they work. will this cause problems with the foglight mod v2
I wouldn't think so as the high beam switch isn't activated, flipped foward, when the drls are on. So if I understand version 2 you take the original signal wire from the headlight switch and wire it in with a relay and that signal is from the low beams iirc
So if I am understanding this correctly, all I need to do is plug in the relay, and have DRL's on my 98 SVT? My old taurus had em, and I liked them. :help:
Adam
Sweet! I just looked under the hood of my SVT, and in the fuse box, and it looks like I can use the DRL module. My next question is, where can I obtain one? Does someone have one they would be willing to sell?
Thanks in advance!
Adam
Thanks in advance!
Adam
info was already posted in this thread ...
might be it.. i googled it.
F6RZ-13B218-0AA for the Contour.
umm, can't you just reach over and turn the headlights on when you start the car..? i do it every day myself?
i beleive they where an option so you will not have much luck finding one in the junk yard but you need something other then a base model car to have a chance to find one ... also it is only $20 from teamfordparts.com which is where I got mone and will be getting another
Got my relay from Bill at TeamFord parts. Having DRL's on the SVT is really cool! It looks great! I need to clean up my headlights, and it will look sooo much better. Cheap and easy mod! Highly recommend! The only drawback, is they don't turn off when the e-brake is set. My old taurus did.
Adam
