Ebay Springs
Uhhh .. I have a problem with my coilover. I can turn the threaded colar (i think that's what it called). I used WD-40 still wouldn't turn. Then I try to loose the nut but it won't budge. So what should I do?
your using the GC's right? not the ebay ones? if you cant break the pinch bolt loose you will have to either drill it out or replace the threaded collar. it happens all to often with both the GC and GC knockoffs. If you still have the knockoffs i would just replace the threaded collars with the ones from the knockoff kit. they work just the same.
edit: before you do though find a set of bolts that are the same material as the nut they thread into.
