Few probs/codes 98 contour se
Tony25
1st code is P0460 Fuel level senson circuit. I have no clue on this one.
2nd is P0171 system too lean bank1. I checked for a vacume leak and didnt see any. Im going to get some maf cleaner and replace the pcv.
3rd was abs/tcs no code
Also the light next to the check engine light flashes looks like a seatbelt/airbag. What could make that flash off and on? Never did this before
that's your airbag light flashing... believe it, or not, its showing you a code. Read the sequence of flashes.
flash-flash-pause-flash-flash-flash-LONG PAUSE would be an airbag code 23 (two flashes, a pause, and three flashes.
The long pause signifies where the code starts over.
What about the P0460 Fuel level sensor circuit? Where is the fuel sensor circuit?
My light is like 4 times then a long pause. Ill watch the patern today.
I dont know by the gas tank ? lol Im pretty new to working on cars so im learning as i go. This is the 1st car ive worked on realy.
The sensor is in the fuel tank. The circuit would be the wiring from the sensor to the fuel gauge (or power).
