BigBEN
JEFF...update...its been 3 days since your last post and im just curious how everything is going?
Thats where im at too. I was going to do a bunch of other stuff.
I need to get the flywheel resurfaced, and im waiting on the transmission
im hoping for early may
You'll have to stop out here when its done
Wasn't able to get my 3L in last Saturday because the clutch wasn't fitting.... I just found out that Spec sent me the Zetec clutch!!!!I feel like this thing will never get done. If it isn't one thing, then it's another.
Rant out.
Jeff
Dang. So it wasn't the pressure plate.
Well Tom, when I talked to you about the problems I was having I thought that I must be doing something wrong... but then I found out I have the zetec pressure plate. So that is why it wasn't fitting! It still fit on the flyhweel dowels and bolted right up, but it didn't clamp the disc like it was supposed to. I'm glad it didn't fit any better because I could have easily installed the zetec stuff!
So could this explain some of the early Spec failures?
I was wondering that... if the clutch disc isn't as snug as it should be between the pressure plate and flywheel, then it seems to me like the clutch would stop clamping after some time even though the clutch disc still has material. Putting the zetec clutch in a duratech can't be good for the longevity of the clutch either way though!
On another note... I am at least another week out until I get my clutch. This is just frusterating...
The Race is on, im scheduling cinco de mayo for my instal.... Now the people of mexico will have something to celebrate, liberation??? Pfffft.
