FauxhawkFox
Fast shipping!:shocked:
I got mine today and ill install tomorrow.
Did I miss the paypal info for this?
You can just touch the button once in the opposite direction and it should stop the roof where it is.Do your relays work the same as the windows? Quick touch is auto and press and hold for manual? If not then an auto open and auto close kit would be either 100% open or closed? To open roof partial would need auto open only so could partially close on manual.
I had a similar question…
Please forgive my ignorance, if this is a stupid question…
But, would I be able to use these on the door windows for auto up and down?
With out doing any research, it would seem to be a very similar application…
ah, I didnt think about what having the auto close relay in would do as well.Actually it does not stop, it just auto opens or auto closes. With the relays I have not found a way to make it stop midway. In my opinion it doesn't really matter if it opens halfway or not (I never open it halfway) when you can just vent it. If you ask people who have done this mod they would tell you the automatic open/close is worth it compared to being able to open it halfway.
There is one way you can get around this. If you get ONLY the auto open or auto close kit it will stop halfway if you press the opposite direction button. However, if you choose to get the auto open and auto close kit this is not possible.
if you want your sunroof motor to be able to open only halfway just order 1 relay and then you will be able 2 do it. Personally I think its pointless to have a sunroof half open. Which is why I got both directions
Well I got mine all wired up and installed. I hit the button to open and the majic worked !!! Then I hit it once to close.. and it worked too.
I open it again, then I go to close it and nothing... This time I have to hold the button down to close.
UGH.
Time to take it all out and see what came disconnected
Thanks. Got mine today. Can't find instructions any where. Looks like both are identical.
Just use these?
http://mrhightower.googlepages.com/moonroofrelay
http://www.contour.org/ceg-vb/showthread.php?t=44587&highlight=hightower
I pm'd you the directions with your tracking number a few days ago. It is a website.
When I PM everyone I ship them to I also PM them with the website for the directions.
