98Mystique2
So I am building a system and I had an idea. Im going to run a 4 channel amp controlling the front speakers and the sub. Im set on the Infinity Kappa speakers, and Steelblue posted 2 kinds. One, a standard pair STANDARD SPEAKERS and some that were a little higher up HIGHER UP SPEAKERS
The higher up pair have a little more kick, so id like to run those off of the amp, but would there be a problem if I ran these in the front and the standard pair of Kappas in the rear, running off of the HU?
Id save a little money and I dont think I would be compromising SQ very much. Can this be done?
I think it would be possible to do that... um i think i'm coming in here late but there are some good 5 channel amps i think jl has a few... they can be run like 2/2/sub or other setups too... make sure you can have a lowpass filter on the sub so it doesnt sound like crap i dont think you can use one on the amp cause you'll be using both the speakers and sub off that if you decide to use a 4channel to power the front and sub. if you get a 5 channel it probably works fine
http://mobile.jlaudio.com/products_amps.php?amp_id=537
http://mobile.jlaudio.com/pdfs/Slash_amps/500_5_MAN.pdf
