Ryan, I have a few ideas on how to get that thing down 1.5 - 2"
On the passenger side, do you have a piece of pipe between those two 90* couplers? It looks like it in the pictures. You could easily remove some material from there, cut the couplers and the pipe beneath them so that side is lower.
Now, the drives side looks to be a bit more challenging. Is that a 180* that goes from the IC?
If so, what does it connect to? Another 90* coupler or something? Can you get me some pics of what is going on on that side?
My hope is that you will be able to rotate that 180* piece downward to get it lower. This will effectivly reduce the distance between the back of the FMIC and the radiator and stuff, but will get you more airflow across the core.
At least that is how I am seeing it based on the photos.
If you care to discuss in more detail PM me your ph#. Don't worry, this can be done. Get some more photos up of the plumbing going to and from the IC and I am sure we can help.
