cobrawannabe
Addicted CEG'er
During my short stint into bikes, I thought about doing it myself. That changed quickly.
-Andy
Don't get into wheel work unless you are prepared for the most boring 4 hours of your life:laugh:
-Andy
4 hours? wth are you doing? you can build and true a wheel in about 15 minutes.... well at least I can.... But then again I have built well over 100 wheels. And that's in the last month alone
I've been at a powder coating shop for a couple months now painting. I shot about 600lbs of powder in the last 4 days. Sadly I only see cool little things like bike parts/car frames come through a few times a week. A couple weeks ago I did the frame, dashboard and a bunch of parts for a 57 Chevy, 3-stage and wetsanding. It looked incredible. I did some Go-Kart frames that night too. Then I painted 350 lawnmower hoods... I think our oven is a bit bigger than the one at your shop, lol
That's when you look for the guy with the "Manager" name tag.I'm still livid:nonono:
Squeeky wheel gets the grease.
Is your rear tire spinning the correct direction? Or does it not matter?
Is it a constant rub or is it periodical? If it isn't constant, the wheel might not be true. Meaning that the spokes were not tightened down correctly. This can easily be fixed though by using a truing stand and tightening down the spokes that need to be tightened.
Nah, I'd know if it was a bent/untrue rim. It's constant.
Huh. For some reason, I was thinking it was my axle alignment.just loosen up the axle in the back. Push the wheel towards the other side, then re-tighten while holding it there. It should hold the wheel away from the chainstay.
I'll give that a shot...
How's the bike look?
EDIT: SHe works! Thanks
