intake
NickNick
hey guys, i bought a cheap intake from ebay,figuring i could use the piping and go get a way better filter. Well i went to go intall the piping and having some trouble understanding wear everything goes. On the pipe there are 3 connections, 2 small and 1 big, the 2 small are for the 2 small vacum hoses, and the bigger one has to be for the bigger hose. know were does the MAF sensor go? there is a port on the part that connects the filter to the heating coil section, but why would i put the sensor before the heating coil? did i get the wrong part or do i have to do some modification to the pipe?
The MAF goes closest to the fender at the end of the pipe the kit SHOULD have come with an adapter to bolt onto the MAF so you can put the filter on.
yeah i got that far, but what about the sensor doesnt need to be on the left side of the maf. cause there is a port that you can put the sensor on the right side, that is before the maf. but ont he stock intake the port is after the maf.
ahh so i guess you do put the sensor beofre the maf, alright ill try it out and see what happens, thx
