Intrest Check: Harness Bar/Roll Cage
Status
Not open for further replies.
As for timing, our cage builder is buried in work. He said he would have a window available to build the first cage in about 60 days. It usually only takes about a day or two to build each cage, so once the first kit is built others can be made rather quickly. If people want a 6 point kit, it would be best to design the 6 point cage first and then the 4 point kit can be made by deleting the front half of the cage. If someone wants to be the test car for the first 6 point cage, we can give you a special deal on the cost, and you will get the cage installed by the cage master. Make a vacation of it and drive your car out to the west coast.
Once the cage kit is designed, we can ship them most anywhere. If I remember correctly, shipping on a 4 point kit is about $100-150 to the midwest and $150-200 to the east coast.
Hope that helps. Let me know how you guys want to move forward. This project does not require a group buy minimum. We just need a test car and orders. If we cannot get a test vehicle locally, you will force me to borrow my mother-in-law's Contour SE for fit up. I could probably use it to get enough measurements for a 4 point kit, but a 6 point would be pretty difficult to swing. Please don't make me borrow her car ;-)
Mike
Do we have pricing anywhere? I wouldnt mind either the 4 or 6 point cage. Is this something that can be bolted in or must be welded? Prices will be anywhere around, guesstimate? I am interested.
- amyn
I am more interested in a harness bar at this time. I like the idea of the 4 point hoop, but I still use my back seats. I will be curious to see your design.
x3, but not because I use the backseat. Just due to price and actual need over want. Really you shouldn't be using the backseat with a harness bar installed either.
if you get access to a car for mock up you should look into a rear strut tower brace as well. Quite a few of us jumped on a GB last year for one that ended up falling through and they are pretty tough to come by these days.
I'm interested in a 4 point cage/roll bar, but don't put me down for one. I won't be able to afford it right now, but most likely I will later in the year. So would there be a problem or anything to order this later in the year?
Also, how about integrating a RSTB into the roll cage/roll bar you guys would be making?
We can look into it.
Once we make them they will be offered as a made to order item.
With the location of the RSTB Id don't think we will do that but we can look into it.
Interested in the 4 point cage. Will this cage be made to bolt or weld in?
- amyn
Weld in.
Located in tigard,Oregon minutes away from Vancouver. I have a csvt with many mods and would be the perfect candidate. Pm me for more info or email me. Troydaggs@comcast.net
That is cool that you are so close. I will email you and get the conversation started. It looks like there are enough people to really make this project go.
Mike
This is what I'm talking about with a RSTB integrated into the roll bar/cage:
I am definitely interested in a cage/harnessbar put me down. is it possible to have the harness bar integrated into the rollcage?
The harness bar is an integral part of the 4 point kit, so you are covered there. I can work with the cage builder to also incorporate a rear tower brace. I am still working with him on options and prices, so as soon as I have anything, I will update the group.
Mike
Status
