SVTJON87
wanted to make sure everyone wouldn't miss anything with the pic
but I'm still at a loss here
dont use the jack. use a prybar to pry the LCA down and then maneuver the knuckle into place. if it wont go back far enough then, like i said before, give a few good shoves till it pops back into place and then try the ball joint.well the problem is when i lift the hub up with a jack the hub pushes the jack out. so its not going strait up. well i think I'm done for today. I'm not feeling my best and will be heading to bed soon. so i should wake up with a better mood toward the car.
I found that by pushing down very hard on the LCA and pushing with my shoulders near the rotor wheel bolts, I was able to move the cv inward enough that the knuckle almost fit in the hole .
This may seem like a dumb question, but do you need to take the brake caliper and disc off? If so, did you have any trouble with these?
i took mine off. i had better acsess to things. its easy, just to bolts and your done. but then again i could do my front brakes in 30 mins.This may seem like a dumb question, but do you need to take the brake caliper and disc off? If so, did you have any trouble with these?
If you could get a new ball joint, drill out the rivets, and insert the ball joint into the knuckle before you bolt the three bolts onto the LCA. Might be easier to line it up?:shrug:
Steve
Tousley Ford
White Bear Lake, MN
1-800-328-9552
(Mention SVT plan for LARGE discount.(from 30-60%!) Don't need an SVT to use this plan.)
