Are you serious?
why would they not be adjustable?
hmm alright.. well I'm reading a lot about lifter collapses and stuff like that. A friend pseudo mechanic told me to adjust my valves. If it can't be done, that's cool.. but how do I fix this noise? I'm scared the engine is going to seize on me.
Hydraulic "lifters" are "adjusted" by oil pressure to put it in layman's terms. Back in the day of solid lifter engines with pushrods, they were adjustable and set, usually cold, to a specific lash or distance between the pushrod and rocker arm so that as the engine warmed up, that distance would lessen but not so much that it kept the valves open when they were supposed to be closed. The distance depended on the cam profile and changing the spec will change the lift and duration. Anyone with an air cooled engine knows about this and this ritual of adjusting the lifters is done every 10K or 20K miles or so. Solid lifters were, and maybe still are, better to have in high rpm racing engines. With the hydraulic lifter, that lash distance is preset usually (some engines had an adjustment depending on the type of rocker arm) and oil pressure keeps the lifter at the prescribed distance. Hydraulic lifters also have the benefit of being quieter than solid lifters but care must be taken to not over rev an engine with hydraulics before oil pressure builds and they pump up or at the minimum, excess wear will occur where they meet the rocker arm or follower. In a pushrod engine I've seen a pushrod fly right by its rocker arm because of excessive lash before oil pressure had built up. Just as hydraulic lifters can collapse in overhead valve engines, it may also be the case in your situation.Are you serious?
Mark, please post your finding when you do get into the engine. The sound in your clip is alomst exactly the same as the one I've been troubleshooting for weeks now! Doesn't seem to affect performance, but loud and annoying! As soon as I have a clear garage, I'll be tearing into mine as well, but I can almost guarantee we have the same issue.... All the additives haven't changed a thing in mine. A high performance engine rebuilder listened to mine, and suspected a sticky valve. Considering the previous owner hadn't been using Premium gas for the past 5 years, it wouldn't surprise me! But I was more on the lifter, sounds more like that...
Keep us posted please!![]()
Karl
you can replace them if youve worked on a motor like this before. in the car is tricky. ive seen some try to take the valve covers off and undo the cam caps and tilt the cams up slightly so they can reach the rollers and the lifters. the only problem with this is that the timing could jump or the chain could pop off the cam gears. this is trouble. id say a safe way is to remove the engine and remove the cams and timing equipment. replace the lifters and check the bearings while your at it, wouldnt hurt. but dont go doing this until you take the valve covers off and seeing if the rollers are all in the right place. one might have somehow kicked sideways and thats what you hear. just my .02
