Stuff to clear out of my garage:
(all stuff used on a 98.5 SVT)
4 used front SVT rotors - 1 warped;
2 used rear SVT rotors
1 set of front pads (later caliper design)
1 set of rear pads (Don't know how many kms on the rotors or pads; You'll need to come look.)
1 aluminum touring wing (pic below)
1 set SVT springs (approx 70K kms)
1 set stock speakers
1 black side mirror cover w/working motor (no door moulding...no mirror either, I think)
1 broken, scratched-up silver side skirt jack cover (both tabs broken)
1 S&B powerstack filter w/coupling to fender vent (as provided by KKM)
1 coil pack (Motorcraft, works fine; ended up replacing when troubleshooting misfire...turned out to be plugs, below)
1 set Motorcraft double plat plugs (at least two cracked, I believe, but I don't think they had a lot of kms on them
Stuff is located in Scarborough.
I'm looking to get $100 for everything; the wing alone is basically worth that. PM is the best way to reach me.
