warmonger
Yup! I really don't understand the entire process of porting the oval ports to accept the split port intake but thats just me
Why not? Its so f'in easy and then it makes EVERYTHING else bolt up correctly because everything else is set up like stock. It helps make your 3L the most compatible 3L conversion done and you can feel confident that no matter what maintenance work you need you can take it to a shop and they can fix it like it was an ordinary contour.
