Thank you! thats what ive been trying to say, but lacked the technical knowledge to lay it all out like that.
Ps:
Ps:
Speed3...Cosmic Blue Mica -![]()
I never said much? That's a very long story that was history a long time ago. Besides, 70% of the members here are dual members at FCO and NECO - Same discussions are on all forums - Perhaps you should "Google" for results instead of relying on CEG alone?
Chill? You think I'm really that worked up...lol. I'm peeved, not angry - The common courtesy you speak of is something that I'm not required to do as I was "discarded" ages ago because certain folks here "knew better than I did". What's the point of telling "eggspurts" that know it all before you say it? There was a reason FCO was born - That was CEG.
Moving on, I've got to outlay the COP details and video.
-D
lol, nice. Go DevilDog!WTF does this have to do with the discussion? "How many members does your site have?" Look at FCO numbers; of the 43xx, how many are active? Here's a hint, nobody gives a phuk.
Let's stay on topic here; as a moderator, my nose does belong. 3 liters, coils and manifolds, great. Panties in a bunch not so much.
My initial test showed the actual powerband these engines would be effective in using realistic redlines for both. The 3L obviously can't hang in the hybrids range because it is limited up top. I said this in my first post. I don't doubt the hybrid is the quicker engine in this case but, one has to look at the fact the the hybrid is also modified to a greater extent.
Someone can clearly see where the sweet spots are, my initial test illistrated that. They can pick accordingly to what they want. Still, we need a full bolt on straight swap for a more precise comparison.
In the 2000RPM-~6750RPM overlay, the straight swap obviously reaches redline sooner because it has far greater low end and midrange TQ. From this stand point it looks better than the hybrid because it can get moving quicker. In a dynamic situation, one has to look at gear changes with respective RPMS, vehicle speeds, TQ, etc..to gain the true answer to the equation. Rather complex, better to just run them.
This test however shows merit if one knows what to look for (the weak points). Compare this with the respective powerband test and we see if we can increase top end performance somehow, we can spank the hybrid anywhere. There are ways to doing this, even with limited cam timing.
As far as my remarks about old components, I stand by them still. Never said the factory had the best engineered components but with new technology and development, the components are better engineered consequently. Why do you think the SBC has become more efficient?
My primary argument is meshing components not engineered with what they are being used with. My attitude may seem rather poor to some for whatever reason, but there is only way to do something, that's the right way.
Any theories that I may come up with are relevant with data I've collected. I have a lot of it for a particular engine I'm working on. I'll say that none of the old stuff and even little of the new stuff is going on mine. Neither is close to optimal.
Many get upset when I say the ports and valves are too big. Well they are, done the math.
Ps:
Again, like your pal BurritaSVT just posted in another thread (what is this? A double whammy?) your graphs are incorrect. You really have no idea where 5252 is, I posted it in the other graph.
-Dom
I have one more question to ask...
When you are doing all this "oval port sucks" theory - What engine are you comparing it to? Give me specs, and the total build cost (minus labor). I'm sure for the same amount of money you have in this "killer hybrid" I could make the straight 3L go the same. I have a "High Power" 3L sitting in my shop right now, I know the owner well and I built his engine. It's a 228FWHP/203FWTQ engine.. The same in that above graph. He has $4000 invested in it.
Do you think your "oval port sucks" comparison has much weight when it requires more $$$ to get there? Any engine that has that much money can "get there".
-Dom
Yeah, it is when you start the dyno 1000rpm higher than the other car!Again, more info posted in the other thread you obviously failed to read.
Let's get this straight so the people in the cheap seats can clearly hear what I am saying.
If you pull a time graph between 2 3.0L engines on the same dyno with the same final drive and one finishes almost 2 seconds before - That's faster. .........
-Dom
