bhiggs89
Well there's your problem
how well do you think a fiberglass box would do? does it resist heat as well as plastic would? i could make a full enclosure with a tube going into the fender and a tube goin into the wiper cowl like cgumm did. the fiberglass can be made any way i want if i hand lay it and it will be super light![]()
People always forget that fiberglass is the original insulation. It loves shielding stuff from heat.
Fiberglass is just glass strands, glass has very little value as an insulator. it is just a cheap light weight material that doesnt burn.
That doesnt explain why its the most widely used home insulator in the world but we're digressing.![]()
Like he said, fiberglass insulation has tons of little pockets of air to get the job done. A fiberglassed heat shield would be a weave of glass and resin and all that good stuff that doesn't leave much air between the fibers.
And it would still do a fine job of blocking heat like a plastic shield would. Hell I've seen plexiglass heat shields with LEDs lighting them up.
i have thought about getting a sheet of plexiglass and heating it up and warping it into shape. a real thin piece would work fine for that. then i could just paint it black. I really hate working with fiberglass, and i remembered why today. ugh stickiness. it was burning through the rubber gloves too. plus i havent done much fiberglass work so it might look like butt lol
That is sort of what I was getting at towards the end. It wont have the same effectiveness as the fiberglass in your walls, but still possibly as effective as a rubbermaid bin.
