rkneeshaw
Contour SE/1996/2.5L/XXY2/17#/Return/MTX
Contour SE/1998.5/2.5L/LTZ3/17#/Return/MTX
This is great. It is going to be a good resource and we'll probably sticky this thread for reference.
This is the kind of stuff that makes CEG one of the best, most organized forums.
Is that swapping the whole ecu?I confirmed today that the SFG0 from a 98.5 will work in a 99 ...
We can confirm the sfg2 strategy/program or what have you can be used on a sfg0 ecu (using xcal2).
yes I swapped the whole pcm, the SFG0 and SFG2 codes for the SVT in my 99 SE ... I plan to dyno in the spring or earlier depending on weather to see how much power I pic up with the SFG0 code, amyeb the SFG2 code also ... but more over the SFGx series of codes seems to be used int eh SVT from 98.5 through 99 ...
What? What? I didn't think the PATS system would allow that !! Isn't the SVT PCM hunting for the chip from the SVT key? How can the SE key start the car without the pcm matching key chip??
