I have a couple of questions about the MAF sensor I was hoping someone could help me with.
For background I've recently started having a hard start & rough idle (along with a P0175 and some other symptoms described in TSB #982310.
Since the symptoms seemed consistent with those caused by a contaminated MAF sensor (per the TSB), I thought I'd try the cleaning procedure documented on this site.
First, I did not have the tamper proof T-20 that I needed to remove the MAF, so I removed the air filter box instead and attempted to clean it "in place" - hopefully this was a bad thing to do.
Looking at the sensor I could see "gunk" on the wires. I uses electrical contact cleaner to clean the sensor. The wires looked clean when I was done.
So I let the cleaner dry off and reassembled the filter box. Unfortunately I did not notice any improvement in performance.
Do I need to also reset the computer to clear any bad MAF readings before I notice an imporvement?
Or did I just do an improper job cleaning the MAF by not removing it completely? I went to Autozone today to get the right set of torx so I should be able to disassemble properly tonight if need be. One thing that I noticed about my sensor though that differs from pistures posted on this site it that I have only one torx screw - the other side of the sensor looks like it's riveted (it's got a rounder head anyway). Is there any trick to getting this apart?
Or I guess the third possibility is that I either need a new sensor or I'm barking up the wrong tree entirely and my problems are caused by something else.
Any advice is appreciated - thanks in advance!
