I don't think "spreading" is an accurate description, but I hear you regarding an ATX issue. So let me ask you all this:
If it's an ATX issue, what would be going wrong with the ATX that would make the engine want to runaway, and to maintain the runaway once the ATX is shifted into neutral/park? This doesn't make sense to me.
Remember, the ATX performs as-advertised, except at high RPMs at highway speeds, where it *sometimes* hesitates to make the final shift (but eventually does when pedal demand is eliminated). Personally, I wonder if the engine misbehaving is causing the ATX to misread the shift cue. As in, the engine's doing 4k RPM, so the ATX thinks you need torque vs speed, and hesitates to give you the final gear.
I dunno...
Okay...TCU transmission control unit TCU... Transmission solenoids..work with the pcm to calculate when and how to shift the transmission.
Solenoids are key to telling the pcm what to do. Seeing these very units control the shifting points in your automobile...i can only see that 1 solenoid going bad could have been your final drive solenoid. Which only means now it another one might be going bad.....or worse your pcm is going bad...which is causing the solenoids to not be reading each other correctly. Thus creating a mutiple effect problem.
Please take the time to visit a dealership and pay for a diagnostic check! It will be around $75-125. That way...you will have an in car diagnostic check while the car is being driven. That way the symptom can be read by the tool so your problem could be found!
Don't start dumping tons of money in different areas trying to find this very problem. Been there done that...:blackeye:
But...it seems that is my diagnoses.
