kscontourkid
kidSVT that is almost exactly what it sounds like.
what exactly was it? you said header gasket? as in the exhaust manifold gasket?
if that is correct then that makes sense as to why it still sounds like i have a small exhaust leak even though i did find one and fix it. i will look extensively into this.
i am testing today to see what i can find. id like to see if i can pinpoint something before i pull the pan. its got a fresh $50 oil change in it and i hate to pull the pan to find out it is not a bearing. that is the reason i am shying away from that as the last possible solution.
i will check the A/C compressor the problem is i have not run it in over 2 months now. (not charged)
you guys have given me some awesome directions. if anyone has any other videos of similar symptoms please post them.
Thanks for your patience.
will hopefully have eliminated some of these possibilities today. and hopefully find the problem.
