Pole120
Addicted CEG'er
Hey Terry, you should post some of your drunk pictures you were posting over at NECO for Pole... that helmet one was fantastic.
It's not a purple helmet is it?
~Josh
~Josh
ctmystique, while I'm sure josh is well aware of this site, I'll post it up for others interested, yes the door shells can be gutted but he'll lose the window or at least window functionality. So I guess thats up to him if he's able to fabricate some lexan replacements.
also I didnt mention but it will probably require josh to weld a few cover plates to the floor boards to cover plug holes, shouldn't be a big deal.
As for the cover plates you're talking about Terry, If I were you, I'd consider riveting aluminum cover plates instead of welding in filler panels, not only is it easier to install it's also a bit lighter and easy to modify in the future if needed.
hey josh, heres a question for you. did you remove the fuel vapor canister [wtf is it called, the thing under the spare tire well]. I remember asking questions about that thing years ago and thought it was 'safe' to remove... but as I sat under the car last night, I was doubting that.
also wanted to throw a few wiring tidbits at you. If you remove the cruise control box, you lose functionality of the horn [shorting pins 1 and 5 of the harness will correct that]. Also the cuise control box area seems like an idea place to relocate the IMRC if you extend the IMRC wiring a bit.
[I think I'll be working on my wiring about the same time you get to yours, so if you want a hand, hit me up, I'd be glad to drive up and assist]
I know it can be removed, you just get fuel odors from time to time. However you will throw a CEL without it, which is why mine is staying.
Electrical Tape?
Or you could get a freakin PRP you slackerFree is a flexible term anyway, isn't it?
speaking of which, how do you pull the damn brake pedal. For the life of me, I cant figure out how to get that damn white plastic peice to seperate.
I have billet 10# N2o bottle brackets. NOS brand aluminum. Real Cheap + Shipping and they are yours...
All that remains to be pulled are that Ppower window regulators and cabin floor sound deadening.
How about some holes in the center section there in the firewall?
