I'm drunk so im going to keep this quick....
3 liter cams > SVT cams. Ive had both and I really don't give awhat the reason is.... 3 liter cams in a full 3 liter own.
Well i guess that solves everything :laugh:
I'm hoping to change that sometime this year.it was not a change in cams only, so we have no comparison (other than the one at the top of the thread) between performance of SVT vs 3L cams on a 3L.
Interesting. After examining most of the above mentioned intakes, (except the ST220 & 09 Escape), it looks to me that the split-port 3L UIM should have the highest max flow potential. Did you forget about it or is there something that limits it in you opinion?In my educated opinion, I believe the stock SVT manifold (assuming split port all the way through) can flow enough air, and in the oval port camp, only the ST220 and the 04+ 3.0L plastic manifolds can support the higher airflow requirements optimally. Of course the new '09 escape UIM is there too.
sicse,i'd like to see a flow bench between the svt and 3L split port uim. i started a thread asking what one people thought would be better on a ported 3l.
so your saying you can take the cam out of your 2.5 svt stock motor and put it in your 04-05 vin s 3.0L DOHC taurus motor, and it will be good, no need for new lifters or anything?
This thread could be stickied and have the picture links saved so they don't go dead.
Ded bummer. I do have the posts screen shots saved.
