He dropped it off at 4:30 today...
I'm also going to be laughing all the way to the bank. I'm 80% sure right now that it doesn't have a blown head gasket. Check out the plugs...
They are spotless. No oil or coolant.
Also, the cylinders are dry. The oil looks like new, not like a milkshake. BUT ...here's the kicker...
There is a TON of slack in the timing belt. I think that it jumped a bunch of teeth.
The previous owner said that overheated and that it wouldn't run after. The overflow hose on the coolant tank is pointed right at the cam gears. I think that with the combination of slack in the timing belt and getting hosed down with coolant, that the timing belt jumped all over the place. That is why there is almost no compression when you check it with a compression tester.
I've still gotta do some more research, but I'm thinking that the motor is fine.
This is going to be the steal of the century if all it is is the friggin timing. LOL!
BP
