She's back in action!
Brian, as far as we noticed, there wasn't any difference in the knuckles :shrug:. Everything fit together perfectly.
Anyways, onto the pics and the story! *dons flamesuit*
So we got the knuckle off the ball joint and strut very easily, and had to remove it from the axle. Meh, usually not a big deal, right? Uhhhhh not this time! Mallet, slide hammer, air hammer, NOTHING could get this effing knuckle off the axle! So I made the suggestion of pulling the axle apart at one of the CV joints. Aircougar popped off the boot, pulled the CV joint apart, and he clamped the knuckle into a vice. With a CRAPTON of PB Blaster, a propane torch, and a huge mallet, the axle FINALLY popped out.
Here's a comparison between the bent hub (front) and good hub (back):
So we go to put the two halves of the axle back together (the two halves had separated while forcing it out of the hub), and realize that it is completely FUBAR. The joint wouldn't go back together properly. Took THAT boot off as well and pulled apart THAT CV joint, and one of the ball bearings was missing (aircougar recovered it and replaced it back to where it belonged!), and the end of the shaft looked like this:
****! The splines were annihilated on the first 1/8" or so of the shaft. I suggested filing the valleys of the splines, but that was too tedious and was most definitely NOT working. Then we found out that the two outer sections of axle are the same between an MTX and ATX, so we took apart a GCK axle and tried to put it into the remaining 1/3 of the axle still sitting in the tranny. It would have worked if it was a Ford and not a GCK! Argh! Soooo, with my 100% approval, he did this instead:
Yep, the end of the shaft, gone. We both agreed that the very end of the shaft is non-load bearing, and is only there to leave room for the locking circlip. It was only about 1/8" trimmed off. No biggie.
So after we got it all back together, I hopped under and took a look at the subframe. I did hit the front corner of it, but as it turns out, the subframe never shifted. The driver's side alignment holes were perfect, as was the front passenger side one. The only reason the reason the rear passenger side alignment hole was off was because a prybar had been used to force down the nut in order to tighten the subframe bolt! (This happened a couple years ago)
So all is well, and with BrApple's assistance in lending me his SE wheels (until my E0's are done), she looks like this:
Oh, and I made a little addition to my car as well:
LMAO! :laugh:
