TGO
King of the OFT
damn, that was awesome
46k on the clock....Hector, you burned up your clutch already???:shocked:
so wait wtf is an antilag??
and hector, did you get your contour back??
Chris anti lag and 2step is the same thing..basically you engage clutch and push gas down..The car will bounce on what ever rev you have it set for...
I have the 2Step/Antilag and mines set at 5k..Now at that 5k im also building/boosting 7PSI off the line, Hence antilag
and no he doesnt have the contour lol
They have dyno drags every weekend in St. Louis and they are able to compensate for the wind resistance. The actual numbers will still be off from what you would run on the 1/4 but they are pretty close.I have never seen a Dyno used like that before. What is the purpose? 1/4 mile numbers will be useless because there is no wind resistance not to mention the resistance on the engine is not the same as the resistance of the car.
So why do you ask?so wait wtf is an antilag??
So why do you ask?
apparently when it's time for bed i couldn't figure out what RET meaned in your sig. i guess it means retired :troutslap:
anyway...so i guess i understand what antilag is. What's the 2step thing? what you guys explained doesn't sound at all like what kevin said![]()
Instead of modulating the throttle trying to maintain revs at a certain RPM when launching, you are able to put the car in first, hold the clutch, and hold the gas down 100% while maintaining the RPMs sit at what is programmed in the ECU. It also allows you to maintain a steady boost level.![]()
