I recently finished up replacing both passenger side and drivers side half shafts on my Contour. When I pulled off the drivers side halfshaft, I lost a good deal of tranny fluid. So, when I finally got everything re-assembled, I added a 1/2 quart of tranny fluid (estimated that was about what came out) and took the car out for a drive and it ran great. Then I let it idle in the driveway for a few miuntes and checked the tranny fluid. I for the life of me can't tell where it is or if its even on the dip stick. But when I went to pull the car a little further into the driveway, the gear shift selector was noticibly more difficult to move. And the engine wants to stall out when engaged in forward or reverse.
Is this indicitive of a fluid level problem? Too low? Too high? Some other problem?
Thanks for your thoughts!
