morbid
You should make a piece of sheet metal to block off the fuse box from the turbo to reduce some heat. turbos looking good man.
Might not be a bad idea to put a hat on the turbo.
Got a couple parts I needed today. So I'm going to get working on it. I'll take pics tonight.
00toursvt, are there any pics you want in particular?
hey thanks, i would be interested in seeing your oil drain line install at the pan and turbo. also, where you tied in all your vacuum lines. and if possible, your install of the tap at the head for the oil supply. if there is too much stuff in the way for a good pic, don't worry about it, i don't want you to go thru too much trouble. i am installing my clutch this weekend and then the next weekend goes on the kit (if i can throw enough miles on the clutch).
this is all greatly appreciated, thanks again, get that thing done!![]()
ha.
haha.
HAHAHAHHAHHA.
here we go again....
Oil drain. Tap it whereever you want. this is where I tapped mine and havent verified how it works yet. The goop around it is jb weld. Bit chipped a little off the surface of the pan when drilling so I jb weled around the fitting.
*pic*
unless there's some kind of pump that we're not seeing.
